show mpls static lsp
show mpls static lsp {summary | {lsp_name} {detail}}
Description
Displays the configuration of one or all static LSPs.
Syntax Description
summary Displays only static LSP summary information.
lsp_name Identifies the LSP to be displayed.
detail Displays additional information about the static LSPs, including packet and byte counts.
Default
N/A.
Usage Guidelines
If no command options are specified, all defined static LSPs are displayed in tabular format. The information displayed includes the configured ingress label, egress label, next-hop router IP address, and the MPLS interface status for the egress path. The summarized list of static LSPs is displayed in alphabetical order based on the LSP name.
The following command displays detailed information about an ingress static LSP:
show mpls static lsp statlsp1 detail
Static LSP Name  : statlsp1            LSP Type      : Ingress-Lsp
Destination  : 11.100.100.55       Next Hop Addr : 12.220.0.30
Ingress I/F  : **None**            Egress I/F    : m3vlan1
Admin Status : Disabled            Oper Status   : Disabled
Ing-Label    : **None**            Eg-Label      : 0x7FF00
IP Traffic   : Allow               VPN Traffic   : Allow
Rx Packets   : n/a                 Tx Packets    : 0
Rx Bytes     : n/a                 Tx Bytes      : 0
The following command displays detailed information about a transit static LSP:
Static LSP Name  : statlsp1            LSP Type      : Transit-Lsp
Destination  : 11.100.100.55       Next Hop Addr : 12.224.0.55
Ingress I/F  : m2vlan1             Egress I/F    : m5vlan1
Ing-Label    : 0x7FF00             Eg-Label      : 0x80300
IP Traffic   : Not Applicable      VPN Traffic   : Not Applicable
Rx Packets   : 0                   Tx Packets    : 0
Rx Bytes     : 0                   Tx Bytes      : 0
The following command displays detailed information about an egress static LSP:
Static LSP Name  : statlsp1            LSP Type      : Egress-Lsp
Destination  : 11.100.100.55       Next Hop Addr : **None**
Ingress I/F  : m3vlan1             Egress I/F    : **None**
Ing-Label    : 0x80300             Eg-Label      : **None**
Rx Packets   : 0                   Tx Packets    : n/a
Rx Bytes     : 0                   Tx Bytes      : n/a
The output for this command was modified in ExtremeXOS 12.2.2.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
